fast shee
My 07 rtx leaks gas when tank filled up. Found fuel on the ground below secondary clutch area after filling it and let it sit for 20 min. I did remove the white plastic neck when filling it and put it back in when done filling the tank to the top. Any common things to check. Bought it used and each time i filled it and let it sit it leaks a bit and very strong fuel smell.
