Cubby's RX-1
- Nov 14, 2003
- Willoughby, Ohio
- www.cubbyscustoms.com
Indy said:Cubby and Welt. I tried to take apart my lens after reading this post. Well the clear lens part is glued to the black base, I could not get them apart w/o breaking. So I went in through the hole and pryed loose the red half egg looking lens, then I reached in with long nose plyers and twisted the red lens to break it apart. It workerd. Now I just need the LED to arrive. Should look really cool.
You stinky little fuggin copy cat you. Thats the last time I share any info on this forum again, Sheeesh. <---- (totally not true)
And Indy, if the LED bulbs are not bright enough, we can always put the red 1157 bulbs I use in my clear tailights on my car and they will be just like having those red plastic thingys. Yea I remember now, those red things are bigger than the holes in the black base.................Cubby
Indy
You share, I am the one who posted the address for the bulbs to begin with. Man you need to get your sled back.
Cubby's RX-1
- Nov 14, 2003
- Willoughby, Ohio
Indy said:Man you need to get your sled back.![]()
You got that right. So you noticed how crabby I am without my sled. How do you think my wife feels..........................Cubby
cwhite3
Has anybody put these in yet. Do you need the rectifier? And do they look cool?
A
Anonymous
I just ordered up two 1157 led lights with the flashing mode.... Hope they work.... I got the clear tail lens with the red globes inside as well, I think I will try to take out the red globes too....
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I was at walmart earlier this week getting a dash bulb and saw that they had 1157 LED bulbs for $6.97.
A
Anonymous
I got the red globes out of my clear tail light. I unscrewed the four small screws which hold the globes to the base of the tail light. I then used a pair of tin snips and cut them up to fit out of the bulb hole... Worked great, no damage..... except for the globes....
i put in a pair last week .they work fine.this is really going to irratate my buddies,(they are usually behind me!)
Bossman
Thosw things would piss me off if I had to ride behind you at night. My buddies would probably bust out my tail lights if they had to look at that. Gives me a headache just looking at the video clip.
michwarrior
- Feb 23, 2004
- Roseville, MI
- www.chippewasnowchasers.com
I have the led tail lights on my RX Warrior. They fit in just like the Stock bulbs. and they rotate around when you dont have the break on.it looks cool
JWL600CC
Mighty, are the ones you saw at Wally World the ones that rotate? Michwarrior: where did you get your LED's?.........Thanks..........Jeff
RX-Dave
- Nov 14, 2004
michwarrior
- Feb 23, 2004
- Roseville, MI
I got them at the Novi michigan snowmobile show in early Nov. I will find the name of the place that sold them to me.....
michwarrior
- Feb 23, 2004
- Roseville, MI
Just found the Company and it is www.britelites.net
I payed like $50.00 for both led lights.....
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Here are some larger diameter bulbs. They claim to be the brightest.
http://www.customdynamics.com/motorcycle_led_bulbs.htm
