NorthernEdge
- Jan 8, 2012
Hello Apex guru's. I'm typically an observer in here soaking up the professionalism you display.
Two weeks ago I removed my skid to replace the exhaust donuts and to add a big boy spring. I got everything back together and it seems tight but I haven't had a chance to ride outside of the yard.
Last night I was cleaning the garage and found this rubber bushing in the area I was working on the garage. It's possible it doesn't go to the Apex at all, I do t recall seeing it when I removed the skid but have no idea where it came from. I've searched the microfiche and can't find it.
Any thoughts? It's about an inch to an inch and a half long.
RAMSOMAIR
That is not out of your skid!
craiger68
- Jan 10, 2008
- Wausau, Wisconsin
- 2020 SRX LE
2020 Viper LTX GT
2007 Attack
Possibly from the transfer rod. been a while since I had one of those out, so I can't exactly remember what it's made of, or if it looks exactly like that.
part #93315-31758-00
RAMSOMAIR
Transfer rod has hard nylon bushings inside
monteberg
- Feb 26, 2012
Is it possible it's a DIY transfer rod damper instead or hard original in an attempt to stop low speed clattering over stutter bumps ?
msgt van
The transfer rod isn't something one would disassemble for this type of maintenance. This part can't fall out of the transfer rod assembly. I agree with RAMSOMAIR's opinion.
I pull multiple skids a year for maintenance and have never seen anything like that picture.
Just sayin'
Just sayin'
NorthernEdge
- Jan 8, 2012
Hey guys thanks for the replies. I'm now convinced it didn't come from the Apex, I found a match on the other side of the garage. I have no clue what it came from but I feel confident the Apex is back together with all her pieces.
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Did you remove the seat?the seat has rubber bumpers attached to underside of seat pan.these may be something someone added for seat to tunnel rubbing?Hello Apex guru's. I'm typically an observer in here soaking up the professionalism you display.
Any thoughts? It's about an inch to an inch and a half long.View attachment 145962 View attachment 145963 View attachment 145962
NorthernEdge
- Jan 8, 2012
I did remove the seat but I don't recall seeing these. Where would they go?Did you remove the seat?the seat has rubber bumpers attached to underside of seat pan.these may be something someone added for seat to tunnel rubbing?
I looked at the parts diagram and it calls for two protector things part number 8FR-2476U-00-00.
I've never seen a part like that on any Yamaha. Drive on!
theCATman
Exhaust was off?
Looks like the rubber bushings that are on the bolt holes that hold the muffler to the chassis.
I would agree but those are only 1/2" thick and he mentioned that the one pictured was 1 - 1 1/2|"
Brotherdan
- Sep 8, 2017
- Belmont,maine
Wouldn't be in the diagram if someone added them.i wouldn't sweat it.no one recognizes them so they either were an added part or went to some other machine/tool etc....I did remove the seat but I don't recall seeing these. Where would they go?
craiger68
- Jan 10, 2008
- Wausau, Wisconsin
- 2020 SRX LE
2020 Viper LTX GT
2007 Attack
I agree with what everyone has said regarding this, and it looks to be solved. No argument here.
The part number I was talking about is the bushing inside the eyelet, not inside the internals of the transfer rod. (I was wrong, but not they way you mentioned)
...also, if you aren't disconnecting your transfer rod before removing a mono rear on an Apex, you are doing it the hard way... Just say'in.
