Lift Jack
allyammies
Darien Wi
Anyone know where to get a lift jack that mount s right on. Mine took a crap tonight. Not sure if bullydog makes one that mounts right on.
Fleet Farm or Tractor Supply. You may have to mod the mount a bit to get it to fit.
I think he's referring to the actual jack on his existing sled lift. I don't think he wants to get a new sled lift or sled jack. Like Tom had mentioned, you can should be able to get one @ Farm Fleet, TSC, Rual King, or pretty much anyone that sells trailer jacks. The key will be to mod the jack to fit onto the lift. I had to replace one on my old sled lift and was able to get a local weld shop to remove the existing mount and weld it onto the new jack. I also had them cut off the foot of the jack (some have a wheel) and then drill the hole thru the tubing right above where they cut off the foot so it could be mounted like the old one was.
