Limiter strap, track tension ?
yamadoo13
me/ma
If I go up one hole on the limiter strap. Do/should the track tension be adjusted? Thanks r
yeah you could check the tension after you move the limiter strap, there is going to be more slack in the track. But not by much.
Hey NytroYK
A bit off subject but how do you like the ZX2 136 on your Nytro. I've got my Nytro cornering fairly flat and don't want to mess that up. Did you see any issues with ski lift?
Brad
Sorry to hijack your thread yamadoo,
But yeah it was running really nice, have the floats at 70psi limiter at mid and spring preload at 4. Still some mild ski lift, but the skid makes the sled a lot taller in the back.
