QCRider
- Feb 27, 2004
- Seacoast Region, New Hampshire
- www.myspace.com
goldbergrx1 said:your like me ...im 6'5" and 300....do you bottom out? and what else can i do other then setting the spring rate, to lessen bottoming out?QCRider said:It might have something to do with the rider's weight... I am 6'4" and 270 before I dress to ride. So if you put that weight on the back of the sled it takes a lot off the front. Besides the transfer is not set by the limiter straps...
Buy the stiffer spring. I just did so I can't report on the results yet...
