wantboost
thinking of buying a used turbo sled with a bender stage 2.anything you guys can tell me to look out for.owner already did a compression test,had 190 psi.don't want to make a mistake.thanks
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
wantboost said:thinking of buying a used turbo sled with a bender stage 2.anything you guys can tell me to look out for.owner already did a compression test,had 190 psi.don't want to make a mistake.thanks
wantboost,
What is the setup on the sled? RX1 or Apex? what stage?
thanks
sledfvr
If its an rx1 make sure it has billet carb caps and tee's. You'll be buying them if it doesn't. Caps are close to $200 and tee's are about $50.
wantboost
rx1 stage 2 bender rear mount,billet t's and caps.
sledfvr
Make sure that it doesn't use any coolant or oil. If it uses coolant then the headgasket is probably leaking and will eventually go out. There should be a 50 mikuni jet in the oil feed line to the turbo so that oil doesn't get in the charge tube.
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
wantboost said:rx1 stage 2 bender rear mount,billet t's and caps.
Find out if it has the upgrade rods and low CR pistons. That would be ideal.
if you can, I'd do a cylinder leak down test.
Also run it hard then stop and see how much blow-by your getting out of the breather filter. Just off idle before clutch engagement rpm.
You should get some normal steam rolling out but not blowing out. Give you some insight if they ran it hard with detonation.
Peak at the tunnel charge tube, make sure there isn't stud gouges in it if they ran the track loose and it's studded on the outside belt. Anyleaks will allow the turbo to overspeed and damage the CS.
Take it to a capable mechanic and have the engine leaked down. Test ride the sled and see if you notice the smell of burning oil at all.
ProstockBenji
- Feb 24, 2005
- Leamington, Ontario
- www.doublediamondacres.com
do a leakdown on the engine to make sure valves , headgasket , pistons , cylinders are o.k. I did a leakdown on a friends RX-1 with 8,000kms and it only 1-1.5% in all 4 cylinders , I also did a leakdown on another friends Turbo RX-1 that only had 2,000kms on it (1000kms with turbo) and it had 30% leakdown in all 4 cylinders , it turned out all the valves were leaking and let me tell you that cost him a pile of $$$$ . anything over 7-8% suspect a problem .
wantboost
engine is stock with 3000 miles on,turbo was installed at 2200 miles.can you do a leakdown with a portable air tank? do sure if this guy has a compressor.i have already rebuilt one of these engines so i know whats involved.
TurboJamie
wantboost said:engine is stock with 3000 miles on,turbo was installed at 2200 miles.can you do a leakdown with a portable air tank? do sure if this guy has a compressor.i have already rebuilt one of these engines so i know whats involved.
Will sell ya my complete turbo sled or SC nytro for the right price
wantboost
this is a complete sled 03 rx1 with 3000 miles and i think the price is right.but thanks anyway
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
Wantboost,
Find out how old that system is. Some of the older ones, the turbo mounting plates were prone to cracking due to the heat where the exhaust turbine housing mounts thru the plate (exhaust pipe joint). This will cause a slight exhaust leak, slight loss of back press but it won't hurt the motor or turbo.
No, the turbo won't fall off... And it's fixable.
wantboost
so do you think i can do a leak down test with a portable air tank?
wantboost, I sent you a pm back call me. Shawnwantboost said:thinking of buying a used turbo sled with a bender stage 2.anything you guys can tell me to look out for.owner already did a compression test,had 190 psi.don't want to make a mistake.thanks
wantboost
sorry shawn didn't see your pm.i will call you tonight.thanks craig
