crash2
- Dec 1, 2005
We have a Radar run coming up in a week and a half and was wanting to know what kind of speeds you could expect to see with a 2006 Apex RTX that is completely stock? Also any good set ups out there that you wouldnt have to finance the farm to get good MPH's have a bet with a buddy that has one.
pedros1983
set transfer full, run 1.450 studs, make sure track is set to spec, check belt, 23 top gear and oh yeah HOLD ON!!! I own 1000‘ setup like that.
SharkAttak
pedros1983 said:set transfer full, run 1.450 studs, make sure track is set to spec, check belt, 23 top gear and oh yeah HOLD ON!!! I own 1000‘ setup like that.
what are you running for mph in a 1000'
pedros1983
not sure of the actual mph, but i havent lost yet. knock on wood. xp 800 doo, 800 dragon, 2 modded rev 800‘s too name a few. By at least 3-5 sleds.
SharkAttak
pedros1983 said:not sure of the actual mph, but i havent lost yet. knock on wood. xp 800 doo, 800 dragon, 2 modded rev 800‘s too name a few. By at least 3-5 sleds.
what are you running 144 gold diggers, mega-bytes?
crash2
- Dec 1, 2005
What gears are in it stock?
SharkAttak
Attak 23/38, Apex 24/38 stock
crash2
- Dec 1, 2005
ThanksSharkAttak said:Attak 23/38, Apex 24/38 stock
SharkAttak
some of the guys change the apex to 23 top gear and change to the white secondary spring and have good results, the Attak came with the 23/38 and the white secondary spring at 3-3 (60), the apex came with a pink at 6-1(70)
rvtransport
I would also try adding alittle weight to end of clutch arm, I found if shifting between 10,200 and 10,400 is best. Most stockers are set up to run in snow conditions and ice the will pull more wieght and gain alot on big end!
