MtN_Rx1er
i hear half n half the stock clutching is well liked with a little bit of tweaking,and the other half will say its crap.
my question is i have a 2004 rx1 mountain(completly stock) and its mainly going to be flatlanded , i find its reving kind of high and was wondering without heavily altering the machine much is there something i can do with the clutching to bring the revs down a little bit?
i talked to a yamaha dealer near me and they said that the clutching needs to be changed, not being specific he just said its a 800 dollar fix after everythings done to basically make it more suited for flat landing but this seems a little outrageous so i thought i would ask on here.
thnx
thnx
It is outrageous set your clutch up to an 05 warrior stock clutch. All you need is the weights and the spring when I get home I can look at mine. I have the exact same machine and use it for flatland too. Turk set mine up and that is basicaly what mine is.
culvert
Sled dog.
Let me know aswell what you are running. If you dont want to give out Turks setup, the please just drop me a PM.
You got it Culvert I am going to post Turk said he would not mind.
yannickapexrtx
Sled Dog said:It is outrageous set your clutch up to an 05 warrior stock clutch. All you need is the weights and the spring when I get home I can look at mine. I have the exact same machine and use it for flatland too. Turk set mine up and that is basicaly what mine is.
i agree and not 800$ cost
