MtN_Rx1er
Hey all, more/less this is just a info topic on the average rpm they usually run at.
so just took the stock 04 rx1 mtn out for some charting before i change the clutching in it today,
currently stock 0-s-0 spring,white second spring.
going to be adding heavier weight for flatlanding.
anyways in my charting my last was to do some climbing and document it for reference, we got a pretty nice hill around us for flatland so i used that.
out of the hole right where it has to start climbing asap 3/4 a lil more its around 9800-10000 and if i wot itl be around 10,100-10,500 , since i am adding weight because im not near mountains or going to be always climbing mass hills, but i would like the odd screw around hill climb from time to time and was wondering what these engines are supposed to rev at when climbing at half to wot
thnx
thnx
The way you are geared your rpms are going to be still high while climbing. Your target max rpm is 10250 when you pin it.
