I don't believe ECP or even Freddie is around anymore. Like Maim stated, K&N still sells their filters (PN# RU-2922) but the ECP kit was more than just filters and outerwears. They used a different Holtzman spring (less tension spring) and larger jets since you no longer had the same vacuum as you had with the stock air box. Additionally, guys like myself also created their own EVAC kit where they routed hoses from the filters to the stock crank case breather. One of the last things Freddie came out was the speed rings which were just aluminum rings you attached to the carbs and then the filters would attach to the speed rings.
