stephenpen
Does anyone have a good flatland tune for an mpi Apex.
I'm running a big head shim, stock injectors, 12lbs of boost.
I'm looking for a tune for 12lbs and 10lbs just incase I decide to lower the boost.
thanks in advance
thanks in advance
I would contact Kinger if you have the gems.
stephenpen
Sorry I forgot to mention I'm trying an RB3 for now. I still have the gems for backup.
It sounds like I will get better throttle response and maybe better milage with an RB3.
FLYBYU
Contact Dave at Powderlites. He might be able to help you. You should've of waited a little bit longer Ulmer is working on pcv boosted with Autotune. Set what you want AFR. to be and it will adjust it self.
stephenpen
I already had the RB3 so I have to try this first. I'm having a hard time getting a map for stock injectors.
If I cant find a decent map I'll be putting the GEMS back in. I loaded the 565cc injector stage two map and the machine quits when I touch the throttle.
