radski30
- Dec 5, 2010
Running Boondocker 2554 Turbo with RB3. I have downloaded the boondocker map from the forums here.
It had a sputter between 7500 and 8500. And at WOT, it would go then it would act a little lean.
I am running a head shim, and stock injectors.
I also cannot get that turbo to spool above 15 PSI.
Does the RB3 data log?
I have the RB3 Master
Any help or advise would be very helpful.
Thanks in advance
Thanks in advance
thamax
thats alot of boost for that small turbo. whats your load and vmin and vmax at? whats your pump correction set at?
