skidooman383
Looking for some opinions on what I should be looking at in regards to what my problem is on my 2008 Nytro. I have just over a 1,000 miles and up until today I have not had one issue yet.
Today we were riding in great snow conditions all day, it was 15 degrees F. The first 45 miles were fine then as we were going down the trail and came to a stop sign I slowed and began to take a slow sharp corner. All of a sudden the sled would not go. I hit the gas and burped the throttle it just would not speed up. I looked at the gauge and the warning light and engine light weas flashing. I did not catch an error code. I then got off the gas and let it idle for a few seconds. Then the warning light went away along with the engine light. I never shut off the motor and I proceeded on. For the next 4 miles it ran perfect. It acted up like this for about 20 seconds total.
Then I met up with my group. I pulled over and idled it for 30 seconds then when I went to get back on I noticed the temp light was on steady along with the warning light. I shut off the motor and looked at the over flow bottle. The overflow bottle was overflowing and both the top and tunnel radiators were hot.
Two more times during the ride the temp light came on so I had to stop and let it cool. I went about 15 to 25 miles between times when the light came on.
Here is my question do you think I might have a bad thermostat?
Also when the engine light flashed and it shut down to limp mode could that be becasue the temp light was on long enough and I just didn't see it so it went into limp. But if it did why would it clear its self so fast?
Any help woulod be appreciated.
