FastAction
You guys with front mounts did you just run pipes to the rear or did you go with a can at the rear?
Modded cans .5 db quieter than stock
spray25
tom said:Looks like the bender stage II only produces up to 220hp? While the MCX produces 240hp? What does the CPR produce?
Can you get more out of those kits safely? I'm looking for the 250+ range.
Bender sends them out at 8lbs of boost vs. MC's 10lbs. You can easily run 10 with Bender too so they are the same.
spray25
tom said:Jonny, good to see another Spokane guy around.
Hmmm another GUY from Spokanne :?
Inside joke
snowy1
I didn,t run anything dumping it into the front of the tunnel no need for the extra wieght.
Jonny Rocket
- Colville, Washington
- 2008 MXC boosted Nitro
spray25 said:tom said:Jonny, good to see another Spokane guy around.
Inside joke![]()
Stop it. I can't take any Moore.
J.
