loose driver collar
Dr. FeeLGooD
Saskatchewan, Canada eh
Working on buddies Nytro and found this collar off the driver. One on the other driver is the same way. He is an easy rider so I dont think it will hurt anything but is there a way to get it back on without ripping out the axle? Has anyone seen this before?
I had one like this on a 2002 Viper but I had to take it out and used a air chisel and a flat tip end to get it back on plus dimple it to tighten it up good luck I don’t know if you could do it while installed in the sled like I said I had mine out !!!
Hi.i am changing my jackshaft on my vector,does anyone can tell me about the bearing on clutch side,is there a specific side tu put back in place.i can't see if there is a tapered side.both side look the same.thanks
