Him
- Mar 10, 2004
- Sweden, the northern coast...
- Sweden
- Apex -11 MCX290
RX Warrior -04
I discovered a weird thing on my -04 Warrior yesterday, was cruising at 8000 rpm on hardpacked trail and the speedo was at 60. I held the throttle fixed but after about 1000 feet it seemed to loose little power and I had to give it some more throttle. I tried a short WOT and it instantly popped up to 10000 rpm and was pulling hard and when I then slowed down to 8000rpm it felt crisp again but after a short while it seemed to loose power again, not much.
When it lost power the first time it felt just like when the hyfax is getting burned so I stopped and checked but that wasn't the problem.
I was running @ 0 feet, the carbsettings are stock and cleaned, track is loose, the filter is firmly bolted to the carbs. The sled has gone 4500km and nothing is changed other than oil+filter.
Is it to lean or what? I have a bad MPG aswell, yesterday I initially was out to test the MPG and got only 14.5. :shock:
