snowfreek20
Ok, I had the drive shaft out and put extroverts on and put new bearing back in, put everything back together and took for a test ride, but no speedo. I have looked in behind the clutch and looks like everything is right where i left it, no damage. do you just bolt the sensor on or do you get it as close to the speedo gear as possible? should i be looking for something unplugged? If your too close to the gear does it not read? any ideas where i should start to look? I'm thinking it has to be right there, considering i had it all apart! Also the speedo did work when i took it apart, the bearing was still intact so the sensor had no damage!Thanks guys!
