Ok my turbo nytro idles low when restarted when it is at operating temp. Sometimes it starts hard too. I just changed the plugs, checked the vac lines with a gauge and ran the diagnostic test on the isc valve So now I am thinking either the therm switch to the isc valve or the ecu (computer) in the front of the sled. I also have a powercommander PC V PTI that I just changed a map to Ulmer racings Map and it runs better off idle. but I am still having low idle when warm seems to rich like not enough air is getting in.
