Nytro270
- Dec 29, 2015
- Alberta
- 08 nytro with mcx turbo
Alright so I did have the sled apart to fix some turbo related leaks and change the plugs. I finally got my parts in for the turbo so I got it back together and went for a test ride... Damn thing wont pull past 7000 RPM (range is 6500-7000). What could be causing this to happen? Is it a wiring issue, do the plugs have to be gapped? To make matters worse I can't even see if the new actuator fixed my leak problem because it only builds 5lbs at such low RPM.. So any guesses you guys may have would be welcomed!
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Hows the clutches? If you pull the belt off can you rev the engine over 7000 ?
Pete
Pete
Nytro270
- Dec 29, 2015
- Alberta
Yep belt off it hit red line at 9300.. what's the fix for this?
herndonp
- Nov 28, 2012
- Freedom,NH
Clean those clutches and check the springs in both. Make sure you follow shop manual on bolt torques and proper settings for secondary.
Pete
Pete
Nytro270
- Dec 29, 2015
- Alberta
Alright, I will do that and get back with the results in the morning. Could it also be the weights? My uncle had a supercharged apex and he said it was very finicky about weights
herndonp
- Nov 28, 2012
- Freedom,NH
I'm assuming it ran fine before with the weights you have. So I would'nt think so.
herndonp
- Nov 28, 2012
- Freedom,NH
any luck yet?
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Can you dial up the boost? Is there a new waste gate spring installed?
Nytro270
- Dec 29, 2015
- Alberta
Sorry it took me so long to reply to you guys. I suppose I have had luck. The problem seems to be cylinder #3 as it isn't firing. (didn't really know what to look for in the way of how it should sound because I've never owned one before now) It has good spark so I'm guessing the piston is fucked. I'll try compression testing as soon as I can get an adapter to fit the hole. The boost however works marvelously as it now pushes 10lbs on half a motor >:/ I didn't think about compression before because it has relatively low kms for a Nytro (or so I had come to understand) at 3500
herndonp
- Nov 28, 2012
- Freedom,NH
Well maybe you will luck out. Could be a loose injector wire or bad injector. If compression is good.
Pete
Pete
Nytro270
- Dec 29, 2015
- Alberta
I guess I'll see what the compression is and then go from there. My brother joked and told me I should just light it on fire haha
herndonp
- Nov 28, 2012
- Freedom,NH
Wishing you good luck. Hold off on the match.
Nytro270
- Dec 29, 2015
- Alberta
So it turns out all my problems have been casued by a broken injector wire.
herndonp
- Nov 28, 2012
- Freedom,NH
Good luck after all!!
Pete
Pete
