low rpm skip on 06 nytro.
snowrdr
Maine
sled seems like has a skip at idle and lower rpm's. comes out of it and runs fine at higher rpm's. i thought possible carb issues but need help from people with more experience than myself.
I would start by cleaning the carbs. Low RPM anomalies typically trace back to the Pilot Jets.
But, ... Can you be a bit more descriptive of the problem.
i should say it's not really a skip. but to better describe it. from around 4000 rpm and less it sounds like it is running on 2 cylinders and over 4000 it runs on all 3 and goes fine.
I would start with cleaning the carbs. I had a plugged Main this year. One cylinder shut right down. I thought I blew a hole through the piston. But, flaky sediment had fully plugged the main and pilot jet in one carb and got one other pilot.
cleaned the carbs. found 1 clogged jet. now runs awesome. thanks again.
