basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
So here is the deal, I got my a arms powdercoated and i ordered the lower ball joint kit from ulmers. I pressed one ball joint and sheeve out and when i did the other the ball split/spred the sheeve. So what the hell do i do now?? the sheeve is froze in the a arm and no idea how im going to try to press it out. Thinkin it might have to be cut? I got 7 monthes before i need it but man this makes me
If the ball popped out then it must have been close to failing anyway.Good you found out now rather than riding.Save the ball and cut the race out with a dremel and carbide.Two lines.Trying not to go all the way through.Then call here and fix them for good:
http://sledtoyz.com/component/virtuemar ... gory_id=10
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Simply take your time and slowly cut the race out. Then install the ball joint kit you already purchased from us.
sgilbert
that happened to me too. used a socket to punch it out with a 3lb hammer. would use press if arm is off. vice would probably do
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
Ok ill probably cut to relieve some stress then try to press it out thanks alot guys
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
I think between the powder coating and the heat from being in the oven is what made it stay in there.cannondale27 said:If the ball popped out then it must have been close to failing anyway.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Me thinks your supposed to remove them prior to powder coating...
For sure.Is a fibre material in the joint that would for sure burn out being powdercoated.
