stephenpen
How much will boost drop with a head shim and cam timing.
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
I'm told a couple lbs give or take depending on the turbo application
stephenpen
I bought this machine that just had the head shim done, timing set and a smaller top pulley installed. I was told it should run 7.5-10lbs this way. But its only hitting 5.6lbs. I did notice it was revving low at 9500rpm Would 1500rpm make a 2psi boost difference.
We have no snow left hear on Southern Ontario so I cant run it again till fall. I only had it out for 15 minutes then the secondary started sticking open.
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
1500 rpm will raise your boost at least 1lb
ScottyD
- Mar 2, 2008
was that the sled advertised on here for sale
stephenpen
Ya. I pickup it up in bracebridge Saturday
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Yes you want 10,500 and your boost will come back. Try a new belt.
stephenpen
Whats the most boost I can run on pump gas with the head shim. I do all my riding on Ontario trails in low elevation
quebecmoutainrider
I run my stage 2 with 94 at 14psi. sea level..got 2230 on it and no issues..A/Fs idel 13-4..mid.12-9..WOT..12-5..12-8
stephenpen
kinger said:Yes you want 10,500 and your boost will come back. Try a new belt.
What mpi pulleys are you running to get 10psi. Are the pulleys marked or do I have count the teeth. Can I unbolt the oil tank and leave the hoses attached to have a look? or does everything have to be disconnected.
kinger
- Jan 17, 2005
- Clear Lake, IA
You have to count the teeth I tun a 26/22 combo to get around 10-11 psi.
stephenpen
I talked to the previous owner about the blower pulleys. All he did was flip the stock pulleys. That gave him 10psi before the head shim.
How many teeth are stock on the stage one kit ?
machzrobbie
Usually its 26-24, or 25-23 to get 10#, both ratios are very close -flip them the other way and you're down around 6# on the stage 1
