Lower Coolant Pipe
Shaf
Michigan
Website
www.fthr.com
I changed my oil tonight and noticed that the metal coolant pipe that runs next to the engine block oil drain plug has been rubbing on the belly pan and it was chaffed pretty good , could be a issue for those of us keeping are sleds for the long haul , i shored it up with some foam to keep it off the metal belly pan.
I saw the same thing with my RTX zip tied it to the oil line to keep off frame .Talked to dealer said was calling yamaha to make sure they knew of proplem.
checked mine after reading this post.1150 miles on my Attak,my hose was rubbing pretty bad also. I put a length of dishwasher hose over the chaffing area and zip tied it in place-problem solved.
