quebec#1
Just noticed that the rear crossover coolant pipe is all loose. Rivets all broke off i just used tie wrapped to tie the pipe so it does rub any longer on the lower bracket
Honk
I found mine rattling against the aluminum tunnel and nearly rubbed it through. I put in a couple rubber wegdes to stop the vibration. worked so far .
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Sounds likle a good time to get a cooler and replace it.
Snowmobileaddict
Its a problem. Crappy rivets.
I swapped rivets for stainless bolts and nylocks on my crossover pipe.
quebec#1
It also looked like mine was rubbing right through , glad i caught it in time !Honk said:I found mine rattling against the aluminum tunnel and nearly rubbed it through. I put in a couple rubber wegdes to stop the vibration. worked so far .
I wonder what the next suprise will be ?
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
quebec#1 said:Just noticed that the rear crossover coolant pipe is all loose. Rivets all broke off i just used tie wrapped to tie the pipe so it does rub any longer on the lower bracket
Caught mine at 8000 miles. Replaced with steel rivets. Also put tie wraps on lower bracket in case they ever came loose again.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Same here caught mine in time, re-riveted and it was loose again after 300 miles so I took some radiator hose and slit it and wedged it in the sides and it worked perfect for the last 1000 miles.
