BTbt
- Apr 11, 2005
- Kettleby, Ontario
- 2017 Sidewinder LTX LE
Does the rear track shock have rebound adjustment? I see a small nut at end of shaft. Specs on Yamaha web site say rear shock is QS3R_
krm
- Apr 22, 2016
- ny
it looks like it does as there is an arrow with a + sign .
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
Yes. that screw is the rebound adjustment. not a knob like the front.
3UR
- Oct 23, 2016
- Pennsylvania
- 2017 Sidewinder LTX-LE
2016 Arictic Cat 7000
2012 Skidoo MXZ TNT 800
- NE Pennsylvania
Owners manual does not show picture of rebound adjuster on rear track shock or the front ski shocks.
The manual states on page 35 Rebound Adjustment is made by turning the KNOB or by using a
SMALL FlatBLADED Screwdriver to turn the adjuster.
Owners manual is vague at best
3UR
- Oct 23, 2016
- Pennsylvania
- NE Pennsylvania
Here's a pic of owners manual
3UR
- Oct 23, 2016
- Pennsylvania
- NE Pennsylvania
Here's what owner manual states on page 36 about rear track shock for QS3
Owners Manual does not list it as a QS3R?
uprider800
- Mar 18, 2016
- winneconne wi
- Arctic Cat xf 9000
Can someone explain what the dampening does? By turning towards the plus sign does this make it rebound faster or slow it down? I never has these type of shocks and have no clue what each adjustment does.
krm
- Apr 22, 2016
- ny
dampening slows down compression ,rebound speeds up shock return to full length .Can someone explain what the dampening does? By turning towards the plus sign does this make it rebound faster or slow it down? I never has these type of shocks and have no clue what each adjustment does.
3UR
- Oct 23, 2016
- Pennsylvania
- NE Pennsylvania
On the QS3R turning the rebound adjuster clockwise slows the rebound turning it counter clockwise speeds up the rebound.
nadekeys
- Oct 20, 2009
- Green Bay, WI
2009 Apex LTX GT
2008 Nytro MTX Turbo
I think about the rebound like a water valve. When you turn it clockwise (remember righty-tighty) you are closing the valve, restricting the oil passage, making it rebound slower. When you turn it counter clockwise, you are opening that valve up, allowing more oil flow and a faster rebound.
Sent from my SM-G928V using Tapatalk
Also rebound does effect compression on these shocks. Adjust rebound for the fastest whoops section you can find. The skid needs to go down into the valleys of every single whoop. So faster without kick is better do this rebound adjustment first before adjusting compression. Helps to have a buddy kneel down to the side of whoops section and watch your suspension because it's hard to tell if you are just bottoming or bottoming because the suspension never fell down in time for the second or third whoop.
