yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I lube the steering of the Apex last night and the rubber boots that slide over the tie rods seem to bind.
Any suggestions. Seemed to get worse when used sray lube.
Yamadoo
Yamadoo
yamadog1
lube
use a dry silicone spray it should help
Tork
they can stick, I also hit them with silicone about once a month.
yamadoo
- Jun 3, 2003
thanks guys will try that
Yamadoo
Yamadoo
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
Well, same thing here. Put the sled up on the lift and the steering is stiff. When I changed my oil filter last month, I sprayed the heck out of every ti-rod, etc. Still stiff!
I will try the silicone spray next!
Attak44
Your problem may not have anything to do with the boots. When you put the sled on the lift, the front suspension drops down and the tie rods rest on the inside of the frame. When you turn the ski's it feels as if its stiff or hanging up somewhere when actually its only rubbing on the frame. Take it back off the lift and the front end compresses and all is well. I lubed everything but the dog one day before I realized what was happening!!!
87gtNOS
- Nov 30, 2005
- Toronto
Attak44 said:Your problem may not have anything to do with the boots. When you put the sled on the lift, the front suspension drops down and the tie rods rest on the inside of the frame. When you turn the ski's it feels as if its stiff or hanging up somewhere when actually its only rubbing on the frame. Take it back off the lift and the front end compresses and all is well. I lubed everything but the dog one day before I realized what was happening!!!
Very interesting...I'll check that too!!
yamadoo
- Jun 3, 2003
Attak 44
I see what you mean the angle is totally different when on ground. I still think I will get some silicone and make it as slick as possible. Probably over kill, but hey I am waiting to ride.
Yamadoo
Yamadoo
Attak44
Yamadoo,
Good idea, I like to use Amsoil spray grease as it seems to work well. Where in SE MN are you located. I grew up in Roch and my parents still live near Marion. Some of the best riding in the state when there is snow!!!! Love the trip from Roch to Caledonia and back around through Stockton.
yamadoo
- Jun 3, 2003
I live near Mantorville, actually have never ridden east of ROch, wear would a guy start to experience these trails.. An y places I could start from trailer.
Yamadoo
Yamadoo
snowbiscuit
Yamadoo, I live just outside Zumbrota, raise the garage door and go. As good as any trails in the state. Let me know if you are interested
