john_the_fisherman
I have an '05 Vector with a Fast M-10. The front lower shaft that the shock and limiter strap mounts to is rubbing on the track drive lugs. This has been an ongoing problem and Fast can't seem to come up with a decent solution. Anyone encountered this and what did you do about it?
Other than the ride, I am not happy at all with my M-10. It is a cheap, poorly made, poorly designed, POS. Especially considering I paid $1200+ for the thing.
WOW, make them buy it back!!!
I have run several M10 and have never had that problem and thought they worked fairly well, I have blown the shocks but nothing else.
yamaman98
I am running a m-10 in my 05 vector, I dont have that problem at all. The only problem I have had is like MrSled, I blew my shock.
sleddheadd
that same thing happened to me last weekend in muni. i changed the hi-fax and it was cured.....let it get a little too worn down.
LazyBastard
john_the_fisherman said:I have an '05 Vector with a Fast M-10. The front lower shaft that the shock and limiter strap mounts to is rubbing on the track drive lugs. This has been an ongoing problem and Fast can't seem to come up with a decent solution. Anyone encountered this and what did you do about it?
Please post pictures of the problem. I would think that raising the shaft to be further from the drive lugs, or lowering the track away from it would cure the problem.
