M-20 in my fx Nytro. Settings and whatnot
Phaze7
Massena, NY
I just recently installed an m-20 in my 2010 fx Nytro. I have only had a few short rides on it to do some basic set up. I guess my first question would be where do you have your limiter strap set? It rides good but is a bit darty and likes to pick the inner ski up on corners. Id like to get the handling locked down before I fine tune ride. I have the limiter strap on the second hole 30 psi in the center shock and 55 in the rear. I turned the front springs up a bit on my gyrt shocks(as my install instructions suggested). I may soften them some to see if that helps. Any input would be great. I posted this on the fx Nytro forum also
