apexxtx
well finally got and installed a M20 in my 2007 Apex ER,install went pretty good,suspention moves freely to about half way,then it gets harder ,from half to full down it seems to stick or feels like it goes over centre,running 35 psi in front and 65 psi in back.Went for a few test drives, it does ride better than stock,but not much transfer,no ski lift or little,limiter set to max,i kinda miss ski lift,but the ride is good,track must be very tight not to rachet,miss the lose track on my mono,any help or thoughts?
yamadog1
m-20
first thing i would call brian at fast 218-744 2107, sounds like you have something wrong.
if you have limiter all the way pulled up that's part of your ride problems. also with this skid you will not get good transfer, your days of front skies in the air are over.
in my skid i run 40lbs in front skid shock, and 75-85 or90 when it gets rough.
You might find your track tension is too tight
Fast skids will bind travel if the track is too tight
If you use Omaha track tension specs it will be too tight
x2 what yamadog1 said. use fast spec's for track tension.
apexxtx
tried,Fasts specs,on track,as soon as you close to 1/2 inch sag,it rachets,and i tried with a limiter and without,not much differents
shouldn't ratchet much with 1/2 of sag with 40 psi in the front.
yamadog1
m-20
if your sure you have installed it properly, it's hard to believe it is ratchets.
my tack is hanging free 1" and i have y/charger with studs and it does not ratchet.
I wouldn't go back. what great ride. drive as fast as you can it will take it.
