How much boost can the nytro stock rods and pistons handle?
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
From my research last year I found anything over 17lbs. of boost at sea level you are asking for trouble on a Nytro. I have over 700 miles running 91 non-ethanol @ 14.5lbs. of boost on trails at sea level with no problems.
BADSLED said:From my research last year I found anything over 17lbs. of boost at sea level you are asking for trouble on a Nytro. I have over 700 miles running 91 non-ethanol @ 14.5lbs. of boost on trails at sea level with no problems.
With a Head shim?
I hope.
Yes I'm talking about head shim and studs.
BADSLED
- May 13, 2004
- Syracuse, NY
TurboM700 said:BADSLED said:From my research last year I found anything over 17lbs. of boost at sea level you are asking for trouble on a Nytro. I have over 700 miles running 91 non-ethanol @ 14.5lbs. of boost on trails at sea level with no problems.
With a Head shim?
I hope.
Head shim of course and factory studs.
Mountaintech
BADSLED said:TurboM700 said:BADSLED said:From my research last year I found anything over 17lbs. of boost at sea level you are asking for trouble on a Nytro. I have over 700 miles running 91 non-ethanol @ 14.5lbs. of boost on trails at sea level with no problems.
With a Head shim?
I hope.
That would be factory bolts.
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
I have a friend running a 2011 Nytro at 17#.he has a head shim and changed the timing, we are at about 800 ft. and he has 3000 miles on it running pump gas. Only problem he has had is the intercooler came apart at one of the welds last week. Quick re-weld and all is good. I run mine at 8-12# with my s/c and no head shim, or timing have about 3,200 trouble free miles so far.
