Max boost out of a bender Stage II?
  • Thread starter Thread starter Anonymous
  • Start date Start date
A
Anonymous
When we got the kit, all we could see was 8psi, we shortened the rod and got up to 12-13psi...
Can I get more boost out of it or I am stuck right there?
See sig for my sled!
SLED
I thought a stage 2 was good to like 21 to 22 lbs of boost.YOu should just shorten your rode a bit more and check fro leaks.Could you post pics of your trubo i havent see a bender turbo apex yet.
cheers
Here is a front view....
This was at the first start time after turbo install...
Is it normal for the wastegate to need a lot of preload to get there?
Right now (12psi) it is already pretty much preloaded...
I'll check that soon!
Sled
Is your waste gate rod as short as it can go?Maybe you should call outlaw motorsports and see what they say they have buit and ridden some meen turbos.So what turbo is it using?
I have absolutely NO IDEA what turbo it is since it is not listed anywhere on the net... but its written GARRETT M24 on the casting...
Anyone have any clue what it is?
And no, its not as short as it can go!
