thebest
what's the max. boost i can run with a front mount turbo with low compression piston 10-1 with no rod changed ???. is wiseco piston are good an off ??? is it the same quality then yamaha piston and ring ??? do you use more oil with wiseco piston.??? thank's for the reply... thebest
thebest
no idea ????
boost
Hey bud
hopefully you put a thick headgasket in too.
I would prolly run about 17psi max with stock rods for very long pulls.
you will need about 102-106 octane fuel.
I'v been told from yamaha that the stock rods have not been tested much over 300hp for long periods of time.
I know MCX pulled 404 hp on stockers but that was 5 -10 seconds.
I say no.
also get a boost guage and controller
good luck
Hey bud
I say no.
good luck
Buckeye
- Lakes Region, NH
I have run 18 for short runs. I have the .054" gasket and Carillo rods and the pistons ofcourse. I believe Phil was going to run over 20 recently.
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
I've got the same question. How much boost with stock gasket and 10-1 Wiescos at 91 oct. premium at 6000-8000ft ? thanks, Ken.
Buckeye
- Lakes Region, NH
I would sy 10 to 11 #'s at 599'. You would have to figure the altitude adjustment. I use 93 pump gas here whne I am not into the boost.
