max boost
Re: wastegate adjustment.
lakercr said:
youngster66 said:
On my bender Turbo two complete turns = 1 psi on wastegate. Does this sound right? Can't remember since I have not adjusted in a long time.
My experience is that 3 turns = 1lb, but that's just a generalization.
agreed on cpr turbo
agreed2 on mcxpress turbo - 3 turns equals 1 lbs of boost on the Mitsubishi 16T turbos found in most MCXpress turbo kits.
ok, i'm in lac du flambeau,wi. now, backed the rod out 5 turns and i'm going to try it out in the morning. I have the boost controller turned all the way down so i can see my new base line and turn boost controller up till i see 8lbs on the guage. will let u know tommorrow night
