Max Lugs Size 2010 Vector ltx gt
Daonlyone74
Wisconsin
2010 Yamaha Vector ltx Gt
Not sure if its been discussed but couldnt find anything yet.
Does anyone know what the max lug height can be on a stock 2010 vector ltx gt? I know stock is 1.25". Will a 1.5 or 1.6" fit without modification?
If they cant fit what would need to be done to fit one? Im a newbie to these never sleds and modifying them.
Keep in mind, even the 1.25 with studs will contact the rear heat exchanger without additional tunnel protection.
I have tunnel protection. Is there any modifications that can be done to properly fit larger lug tracks or is this sled stuck to keep a 1.25"
Unless you remove the tunnel protectors 1.5” is as tall as you can squeeze in there. Forget studs with a 1.5” track as well, you’ll have mega contact trying to run them and cause tons of damage unless you swap out to 8 tooth drivers and space the skid down out of the tunnel.
1.5" will have clearance. 1.6" will be really close. just spent 2 hrs looking at the tunnel protectors on the cooler by the drivers on my 11 with the 1.5" track.
Do you still have the protectors on with the 1.5" ?
yes i do.
The track runs pretty close to the protectors everywhere with a 1.5”, just hung one on a ‘14 Vec. with the protectors left in.
