JohnnyHollywood
I've been looking for the chrome trim piece at the base of the riser block on the attak's and apex's. I want to add one to my phazer, it looks like it would fit. There's just one problem... it's not listed in the parts catalog. Any suggestions?
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
Will it fit? - yes and no.
Yes the chrome trim ring from the Apex's will fit because the steering post has the same bolt pattern.
No it will not fit because the actual riser on the Apex is different that the one on your Phazer. The profile is different, and there is a notch cut out on the bottom of the Apex riser, which is a clearance cut for the trim ring.
You can get the part numbers from the online Yamaha microfiche. If you decide to go with the chrome trim ring, we make a billet bar riser setup that accommodates the chrome trim ring.
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
I think you need to look on the 'control cable' page.
JohnnyHollywood
thanks gade, I was planning on getting a set of your billet risers.
