Tyloooor
pm me that setup too....please and thanks
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2015 Viper X-TX LE MPI turbo
2009 Nytro XTX
Shadow 44's post with Turk's black spring set up...
http://www.ty4stroke.com/threads/turks-nytro-drag-n-fly-clutching-with-black-spring.116830/
mnman309
I heard there is a search function..... !
I should use it once in awhile!!! thank you
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
It actually doesn't work that well (poor Turk is probably swearing at me from up above right now lol)...I have better luck searching in Google.I heard there is a search function..... !I should use it once in awhile!!! thank you
shadow44
try thisShadow 44's post with Turk's black spring set up...
1 bolt 3 washers in arm
1 bolt in od
1 bolt 1 washer in tip
centre empty
run black hc spring
With this set up I was hitting around 9050 rpms around 1000ft...engagement was about 3800 rpm....leave the secondary stock. My sled ran best with this set up...I walked a lot of sleds with this clutch set up and my bolt ons.
