Stoli
I installed a MCX 180 kit this fall. Starts and idles good - when i give it some throttle it back fires quite a bit. Flames and sparks.
It still has the old fuel from last January - i need to change that out.
Could that be the issue or has anyone seen this before.
Idles good - back fires when i hit the throttle.
Help please. Heading to MT in 3 weeks. We are looking at heading to MI this next weekend for a tune up ride and i would like to address this before getting up there.
Drain fuel immediately.
It is very likely that there is a fair amount of moisture in it, and that is a wreck waiting to happen.
Put some 91 in it... or 93 if you can find it out there.
Post up results.
Post up results.
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Sidewinder XTX 240 Sidewinder Alpha MCX 270.
Can be the T.O.R.S. check your throttle cabel.
YamaMTX
- Feb 7, 2009
- crosslake MN
- 2009 Yamaha nytro and polaris 600 rush
Stoli where are you headed in MI? I did a Ulmer kit and also am looking for a tune up ride.
Stoli
YamaMTX said:Stoli where are you headed in MI? I did a Ulmer kit and also am looking for a tune up ride.
Not exactly sure yet. Probably between Ironwood and Twin Lakes
Stoli
Seems to have been a bad ground - thanks Alan and Scott.
Put a new subframe in and had it powered coated.... needed to sand off that front grounding area
YamaMTX
- Feb 7, 2009
- crosslake MN
nice find! If you ever have a spot open let me know. I like to go to MI and also out west.
Super Sled
- Feb 25, 2009
- Summit X
YamaMTX said:nice find! If you ever have a spot open let me know. I like to go to MI and also out west.
X2 Stoli!
YamaMTX
- Feb 7, 2009
- crosslake MN
Super sled, what did you get for snow? only 2 inches here
Super Sled
- Feb 25, 2009
- Summit X
Ya not much here or up the shore. Supposed to get two to five inches, but got two at most
