Hi !
My Nytro now has 1017km on the clock and I love the sled more and more.
But I constantly find myself dreamin/thinking of a turbo kit.
How hard is the installation of the kit?
I consider myself as fairly skilled mechanic so I figure I should be able to mount it. But... It has to be 100% perfect.
How many evenings will it take to mount it?
However I do have some concerns:
-If I crash the sled, what will the insurcance say when they find out that the sled has more power then it should have?
-Engine warranty, what if it breaks down? Will it be covered? (guess I will have to talk to my dealer about this)
-Quality and reliability of the MCX kit?
Any opinions appreciated!
Anyone?
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
I have the mcx 200 apex 2011 kit.
About 18 hrs to install , hardest parts is fitting the aircharge tube , dropping the suspension and refitting the stud protectors if needed.
A great kit , plug in wiring , pump fuel and go.
We went 3400 k since install , flawless and fast.
Inurance dosen't care.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
MCX180 doesn't involve any motor work. A little cutting of tunnel and frame. The rest is a pretty straight forward install work. Doing it right it will take you about 25 hours.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Forget to say, quality is very good on the 2011 MCX turbo kits. Are you far away from me?
Hi there!
Sounds good! Great!
I talked the local dealer he said that they used 1 1/2 day to mount it, I`ve worked there for a year together them and they ment I should be up to it so I feel confident
The only thing being "tricky" was that the exhaust had to be removed, then put it back on, then spot-weld the exhaust onto the turbo flange, then remove it and weld it properly and then put it back on=)
I hope I will be able to mount it on 3 evenings after work so that I can ride it next weekend. Will probably get the kit on Tuesday so... .
I live north in Nordland close to the border to Troms. (live on and island called Tjeldøya, an hour drive from Harstad)
Sounds good! Great!
