mdkuni
I think I am missing a washer for the secondary on the outside. I have the one thick washer that contacts the bolt head then I have a 1mm washer and that is it. Is there supposed to be another 1mm or .5mm washer? Just wondering what comes stock.
mdkuni
Can anyone check on this for me, I am trying to get her put back together. Thanks.
Metallicat
I was wondering the same thing about my Vector since it only has 1 washer but the parts diagram shows a possibility of two washers (one 1mm and the other 0.5mm). I was thinking that perhaps I lost one last year when I had the secondary off but maybe this is just how they come?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I think I only had one on my Vector. I believe I had 2 washers on the backside though.
AttakDog
I wouldn't sweat it too much, the secondary will float somewhat to self align and one small washer isn't going to hurt anything....
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
check your offset boys you will need the washers to adjust to to get the proper offset you can run them lock down it will not hurt anything I have been doing it since 1976 when i was racing
Honk
I had two in front and two in rear. large and small in both
