Apex Enthusiast
- Mar 13, 2017
- Michigan
- Apex LTX
The mode button won't switch settings to rear shock. Left on grips yesterday, today button doesn't work at all. Any ideas? Thanks in Advance!
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Likely a broken wire. Very common.
Apex Enthusiast
- Mar 13, 2017
- Michigan
- Apex LTX
Where is the most common place for a wire break? Thanks! It wont select grips either...Likely a broken wire. Very common.
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
If it won’t select grips either it could be the cluster itself, ecu, ground blocks......
Use the search function and start reading.
Apex Enthusiast
- Mar 13, 2017
- Michigan
- Apex LTX
Wasn't having much luck searching. Posts referring to wires broken, or bad solenoid... Any ideas for search words? No results on ECU, or ground block pertaining to mode selector...
Apex Enthusiast
- Mar 13, 2017
- Michigan
- Apex LTX
Winderallday!
- Dec 4, 2007
- SW, Ontario
- 2018 Sidewinder DX
First place I would start is with the rocker switch itself, if you can get into it to check the contacts etc.
Apex Enthusiast
- Mar 13, 2017
- Michigan
- Apex LTX
The rocker seems to work fine, controls grips up or down... Just no response from mode button. Last time I used it I left it on grips. Cannot see any damage to wire at shock, it did have a big ice chunk hanging from wire. Thawing it out now for a better look...
blown apex
- Jan 29, 2006
- ALTON ILL.
- ristermotorsports.com
my 2006 apex gt did this ,the wires were ripped off by ice and must have shorted to them selves or ground
after fixing the shock wiring. it still didnt work
i swaped ecu with my other apex er (no electric shock) and it worked fine
it must have burnt out the shock driver circuit
