ecopter
Besides the stock bushings for the rear mono skid, who else makes these?
Thanks in advance,
Jon
Thanks in advance,
Jon
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
ecopter
I only see Front End busings on his site; not rear. Does he carry the rear?
Jon
Jon
motohd66
i know a couple years ago nobody had aftermarket bushings for the rear skid
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
in 2010 yamaha is putting bearings in wait ontil the 2010 parts manual out and put the bearings in
mork110
Ulmer Racing do not make a kit for the rear skid. The bushings are too thin in the rear skid to properly use oilite bushings.
big_red1a
rear bushings
Has anyone put bearings in yet? do you need to do any modifications or just straight install?darv said:in 2010 yamaha is putting bearings in wait ontil the 2010 parts manual out and put the bearings in
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Re: rear bushings
i cant see this working....the new mono has many many new parts,....i think you would need the whole arm to add bearings,and im not so sure the new arm would even retrofit into the orig mono skid.
Dan
big_red1a said:Has anyone put bearings in yet? do you need to do any modifications or just straight install?darv said:in 2010 yamaha is putting bearings in wait ontil the 2010 parts manual out and put the bearings in
Dan
darv
- Aug 9, 2005
- 08 Apex 40th LTX
no you can put the bearings in or put different bushing from pioneer performance Part # P-S129 06 and newer Monoshock bushing kit $67.00 old catalog
big_red1a
rer bushing
you have actually put the bearing in? Does pioneer still carry this part i though it was to thin for an oil-light bushing what is it made of?darv said:no you can put the bearings in or put different bushing from pioneer performance Part # P-S129 06 and newer Monoshock bushing kit $67.00 old catalog
darv
- Aug 9, 2005
- 08 Apex 40th LTX
it say that they are made of NYLATRON is a oil and glass inpregnated plastic which is self lubricating. with the bearings are only on the are part that mounts on the rails i have ordered the parts and some are not in stock yet. if you look at the parts list you need # (16) seals 4 # 93109-17071-00 , (14) nuts 2 # 90185-10011-00 (15) bearings 2 # 93315-31750-00 (13) Collers 2 90387-10095-00, I look at the apex 2010 parts catolag, from looking on the list and compare to last year this only the up-dated parts on there
darv
- Aug 9, 2005
- 08 Apex 40th LTX
