Mono skid instalation in a vector
hon23c
Help, Went off the deep end and bought a 05 RX-1 mono skid to install in my 05 Vector. I am in need of some dimensions because it doesn't just bolt up. If with somebody with an 05 RX-1 or 06 Vector with a mono could measure the distance from the drive shaft to the front and rear mounting holes and from the top of the tunnel down for each of these holes it certainly would be appreciated. Thanks in advance Guys
I installed an 06 mono RTX skid in my RX-1. These are the measurements directly from the 06 RTX which made my installation easy.
The measurements you need are:
Center of driveshaft to center of front hole = 11"
Center of front hole to top of tunnel = 5.5"
Front hole to rear hole = 20.5"
Center of rear hole to top of tunnel = 7.25"
These measurements should get you started, keep in mind, these are the Apex measurements and yours may have differences (like tunnel clearance) so be sure to measure many times and drill once.
Good luck, and have a great riding season.
Otis
Otis thank you very much for info, I do not have access to the sled the skid came off. So your info is very valuable.
thanks again
thanks again
