I just bought a used mono skid with about 800 miles from lighting pro, was wondering if there is anything good about this skid, because all post are negative and seems every dam part needs replacing.
LazyBastard
If you can find out who owns the sled it came off of (ie for VIN and authorization), then you should be able to get the recalls done to it.
QCRider
- Feb 27, 2004
- Seacoast Region, New Hampshire
- www.myspace.com
You can't get them done for free unless there is damage to it already. The dealer won't just update it if nothing is wrong. I talked to Kevin at Port the other day and he told me that other than the W-Arm (which is not an issue for me since I don't ride rough trails) the things you need to change are the bushings at the top and bottom of the W-Arm and the little short shaft that rides inside the bushing and arm. When you change this you need to be sure to order the '06 part number because they changed it from aluminum in '05 to steel in '06. Other than that I bought new wheel with replaceable bearings and rubber on the outside to replace the all plastic non replaceable bearing wheels. that came in the '05.
