Monoschock boggi
offside
North sweden
Need some tips. Have fixed and schims all shocks and "sag" is 40mm, control rod is in the centre and limither strap is in third hole ::::: from right. I drive stage 2 turbo kit mcx 290hk. Had some problem with track ratcheting before i set al of this. Thinking of control rod and limither strap. have no ratcheting now, but like to have more bite. Hope all of you unerstand what i mean.
Regards / Tobias
I now that this question have been ask before. Have search after a good answer but have not found one. What do you think of setting control rod to max weight transfer and leave the limiter strap in third hole so the track will not ratcheting, that would give me some more fortress in snow?
Have tested now with good result. 1,1 bar no ratcheting. Do you guys put fuel booster in your turbo sleds? better?
Traction and Fuel booster
Fuel booster is a waste, doesn't do much at all from what I have read.
I have my control rod set at max weight transfer and use ski-doo summit track drive sprockets to eliminate ratcheting. You must have all open track windows to use these drivers.
Good luck
Ralph
Re: Traction and Fuel booster
Good luck
Ralph
Thanks for the help. Did not whant any more hp, just to be sure that i have good fuel, always put 98. Have skidoo nonslip. all open track windows. Have put the control rod to max transfer of weight and limiter strap in hole nr 3, use to have in 1 down from stock. Stock is max loosen.
Test drive to the weekend:)
