APEX 21
This a probably a really stupid question. If you continue to turn your tunnel adjuster clicker in one direction what would happen. Does it reset once it goes around or not.
I think my kid turned it a couple times.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I think it goes two complete turns for 720 degrees clockwise,which would be full hard,just turn it ccw to whatever setting you desire,and you should be ok.
Swiss Sledder
First, ground your kid for touching the sled. Second, don't worry about the dial and the amount of clicks as it has a limit. I go 185 without gear and I had the dial set on 4 clicks from the softest setting on my 05 RX-1 and did not buttom out the sled.
APEX 21
thanks
