Rx1M5
In an effort to only take the carbs off as little as possible I'm looking for the some input on all the jetting specs. After talking with several people I'll list what I've got to date. Riding 6-8000 feet 10-32 degrees F. CPR front mount with a GT25.
Main Jets 127.5
Starter jet 25
Pilot Jets ______??
Pilot screw turns _____??
Needle Clips _______??
Plumbing Questions: Here's what I'm led to believe:
1. Connect the 2 lines from the billet tees to each other via a tee then attach that line to the intercooler?
2. Join all 4 carb boot nipples together 1 end of the line goes to the boost guage, the other end of the line goes to the BOV and a tee from the center goes to the fuel pressure regulator?
3. What becomes of the carb vent lines? Tee'd then attach to the intercooler?
That should keep me busy for today
Thanks Rx1M5
Main Jets 127.5
Starter jet 25
Pilot Jets ______??
Thanks Rx1M5
