moto4_lane
- Jan 26, 2008
i have a moto 4 that was getting over 100 kilometers a tank. last time i checked it was closer to 70-75. i have changed the seat in the carb, but no dice. how many kilometers should i be getting a tank anyway? its a 12 litre tank for those wondering.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
all depends on the type of riding. all at a cruse on hardpack will be better than running the mud. i know my bear gets over 150km before i have to put it on reserve to get back to camp. mine is one of the thirstyer bikes at the camp. only one that is worse is a 500ho polaris. the rest other than 1 kawi 360 alll are close to mine in fuel milage.
moto4_lane
- Jan 26, 2008
well i was gettin around 130 k a tank. and then 70-80, there seomthing wrong there. though yesterday, i went out for a afternon on it in the snow (about 15cm with some trails broke). i burned half a tank in 13 kilometers. like i said i changed the seat in the carb, and i havent really measured the kilometers yet, but that (13 kilometers in snow) was after i did it. doesnt seem right to me. ![Banghead :o| :o|](/styles/default/xenforo/smilies/banghead.gif)
brakes and bearings adjusted properly?
if chain drive, is the chain clean and lubed?
something has to be making it work harder than it used to.
moto4_lane
- Jan 26, 2008
no brakes, seems to have good bearings. timing chain has to be adjusted though.. btw it's shaft driven.
moto4_lane
- Jan 26, 2008
just to be specific its a 1986 yfm225.
chech that the choke is closing properly. if it is cable, it might be hanging up.
moto4_lane
- Jan 26, 2008
wouldn't i hear it idling high though?
not if someone turned the idle down. if it is not that, there might be an o-ring missing/cracked on the jet .
moto4_lane
- Jan 26, 2008
i know the jets are a little warn.
moto4_lane
- Jan 26, 2008
i have noticed its a little worse for cold starts this winter.
try some new jets if you can see visible wear on them, that is bad.
moto4_lane
- Jan 26, 2008
ok i will try to get those changed
Jaxom
Check and/or change your spark plug. That will tell you if you're running rich/choke stuck on.
moto4_lane
- Jan 26, 2008
yeah i am going to today. im going to replace the jets, and see if the choke is stuck to. its getting around 27MPG i think
