Apex2006RTX
Hi,
I just finished my first oil change and now worried about a little something i done!!! When I had it apart i gave a little turn on the munt bolt and did get a click out of it but know wondering if it will take her out of line!
bashley
I'm sure somebody on here will be more "knowed up" than me on this but I would think you could either take that "click" back out or give the rest of them one. I personally wouldn't loosen it back up but I could be wrong. I'd even bet that It'll be fine the way it is.
grader
nothing to worry about, the motor is adjusted with bushings that the bolts go through, not the bolts themselves.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
no worries....i had my motor out and you gotta move those alot to get a slight change in alignment.
I like to check my clutch alignment closely anyway....use a staight bar and measure 15mm behind secondary at front and rear.
check out this thread i posted in....
http://www.ty4stroke.com/viewtopic.php?p=461179#461179
Dan
Dan
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
all good!
