jpilk99
- Dec 11, 2021
- Bolton, MA
- 2006 Yamaha Apex GT
I know I’m in the rear-suspension adjustment mode as I see the correct icon onscreen. But when I hit the left Control buttons up & down, it doesn’t change the displayed setting. I recall the very first time I checked the suspension setting and saw that it was set extremely hi. So I hit the down button with my thumb and down it went. But I can’t make it go back up. It’s all the way at the bottom now. Oddly, with it showing the lowest setting, if I click the down button, it actually goes up one position; (but that’s it. Hitting down again just makes it go down). Could the “up” side of the blue button be fried??
RobX-1
- Coldwater, OH
Does the "up" button work when in the handwarmer mode? If not, then yes, the up button could be bad or just needs a cleaning.Could the “up” side of the blue button be fried??
jpilk99
- Dec 11, 2021
- Bolton, MA
Good point, I'll go check. Thank you, RobDoes the "up" button work when in the handwarmer mode? If not, then yes, the up button could be bad or just needs a cleaning.
jpilk99
- Dec 11, 2021
- Bolton, MA
Nope, up doesn't work on handwarmer. Need new switch? Can't get inside and clean the contacts, can I ?Does the "up" button work when in the handwarmer mode? If not, then yes, the up button could be bad or just needs a cleaning.
yes you can take it apart and clean it.Nope, up doesn't work on handwarmer. Need new switch? Can't get inside and clean the contacts, can I ?
jpilk99
- Dec 11, 2021
- Bolton, MA
Awesome possum. I'll start searching for DIY vids!!!! Thank youyes you can take it apart and clean it.
jpilk99
- Dec 11, 2021
- Bolton, MA
Has anyone seen any videos/instructions on taking this apart? I took the 3 screws on the inner coupling out and the plastic cover they held in. I can see the back/side of the switch, but, just leery of how best to get inside to inspect & clean. Thanks for any help.
Jay
Jay
RobX-1
- Coldwater, OH
This might help:Has anyone seen any videos/instructions on taking this apart? I took the 3 screws on the inner coupling out and the plastic cover they held in. I can see the back/side of the switch, but, just leery of how best to get inside to inspect & clean. Thanks for any help.
Jay
https://ty4stroke.com/threads/hand-warmer-button-not-working.164059/#post-1578851
jpilk99
- Dec 11, 2021
- Bolton, MA
That helped a lot. Thanks Rob. Not sure if it's stated in any of that link, but, I did find 2 extra screws at the bottom of the whole "button assembly" that may not have been mentioned to be able to remove the entire assembly. Come straight up from the bottom. Other than that, pretty much spot on. And once apart, it wasn't so much that the brass contacts were dirty, but, I believe the small half-inch sized little brass "plate" with the 3 nubs on it that rest against the spring behind it, that plate was out of place. Cleaned everything while in there and made sure the plate was properly in it's place, put all back togetha and ...BAMM. Controls now work in both directions.
Thanks all.
- 11K
